Can't shift out of park, brake lights not working
Old 05-12-2024 | 03:18 PM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
My pleasure.
George
Old 05-18-2024 | 02:31 PM
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
Printed out some wiring diagrams, going to try to see what's wrong today.
Old 05-18-2024 | 02:59 PM
GeorgeLG's Avatar
Let me know if you need any help with your testing
George
Old 05-18-2024 | 03:11 PM
At the moment the brake lights are more important, going to concentrate on that. I guess starting at the lights themselves and working my way back is the way to go?
I have an electronic version of the FSM. The only wiring diagram I could find for the brake (stop) lights has "export" listed next to it. Hopefully it is the correct application for my truck.
Old 05-18-2024 | 08:42 PM
GeorgeLG's Avatar
Here is your wiring diagram. Usually I will start anywhere that I have other info that makes that test point suspicious, like your new MF switch/disturbed connectors and wires. Then the point with the easiest access. IOW, I will look for voltage at the fuel pump priming tab before I drop the fuel tank. If none of that holds true then start in the middle and rule out half the circuit, then go to the indicated half and cut that portion in half. This will get you there faster, statistically. Let me know if you need anything else.
George
File Type: pdf
Blazer RealSteel
07-06-2012 07:38 AM
woodworkewr4421
02-12-2012 03:55 PM
able_onar
06-15-2011 12:03 AM
stabman
01-04-2011 08:07 AM
reynji
06-04-2009 03:33 PM
Quick Reply: Can't shift out of park, brake lights not working
