Can't Shift From Park When Cold
Old Dec 27, 2011 | 09:51 AM
pettyfog's Avatar
My thoughts.. though I didnt think it worth writing was 'sticky lockout solenoid'. Didnt respond because I wasn't sure it applied.
I did have that sticky lockout problem in a Taurus {I think}
NOw I remember it happened to me a long time ago. Drove through deep water in an older car and the next morning I couldnt get shifted out of park.
That evening it worked fine
Only happened once and I connected the two, figured the trans side boot was cracked.
Fix would be same as parking brake sheath/cable.
Pull boot on opposite end, blow air down through sheath..
Lube {chassis or white lube} both ends of actual cable a LOT and work through full travel many times. Repeat.
You might try WD 40 from top end, but remember WD 40 is NOT a lube, it just frees up sticky parts {usually sticking from dried out lube}. I would follow with Silicone spray, at the least or come back later and do the chassis lube trick.
Old Jan 2, 2012 | 03:11 PM
TheRandom1's Avatar
Bigeffinghammer did this solve your issue? It sounds like I'm having the same one as you.
Old Jan 3, 2012 | 03:31 AM
BigEffingHammer's Avatar
BigEffingHammer is on a distinguished road
I've yet to check anything, it's been too damn cold and I just got a horrible head cold, however, it's supposed to be low 40's Friday, so I might go take a look then.
UPDATE:
It was a beautiful 51 degrees today so I went under my Blazer and I found the problem (or so I assume).
It was rubbing on the frame between the transfer case and the transmission.
Image one: This is where it was rubbing
Image two: This is a poor image of the spot rubbed away
Image three: I then followed what I was told to do and sprayed some WD-40 in there
Image four: I also unbolted a cover on the transfer case to allow more slack in the cable
Attached Thumbnails Can't Shift From Park When Cold-100_2888.jpg   Can't Shift From Park When Cold-100_2889.jpg   Can't Shift From Park When Cold-100_2891.jpg   Can't Shift From Park When Cold-100_2892.jpg
Old Mar 4, 2012 | 03:52 AM
Welp, attempting to fix that did not work at all for me. On the next extremely cold day I was late for work and it was not working, so I was really wrenching on the shifter, and once I was able to shift it into drive and go, when I got to work, it wouldn't shift back into park, it would just be out of gear, so I just went ahead and replaced the entire shift cable.
$96.XX from my dealership, took a couple hours because I was learning as I was doing it, I could probably replace it again in ~45 minutes.
grounded87
Jun 29, 2011 09:12 PM
bama1fan
Jan 12, 2011 07:30 PM
TheBigOldDog
Jul 7, 2010 05:11 PM
AntonyJ1214
Jan 3, 2010 10:21 PM
GCM
Nov 19, 2008 10:39 AM
