Catalytic Converter Heat Shield
Old Sep 23, 2012 | 04:05 PM
Jesster's Avatar
Jesster is on a distinguished road
Default Catalytic Converter Heat Shield
I have been having a noise from under my 1996 S-10 Blazer 4dr 4wd. I found that the converter heat shield has come loose from the two front spot welds and is still held on with two spot welds at the rear of the shield. I checked with a trusted local exhaust expert and he said that I could just remove it completely. In his experience (he owns a national chain franchise), 2nd generation Blazers in the mid to late 90's had a problem with the heat shields falling off and that 9 out of 10 that come into his shop are missing already. He installed a universal replacement catalytic converter about 4 years ago and said that "in his opinion, I don't even need the heat shield".
I realize that catalytic converters get reasonably hot. Has anyone dealt with this before and can I just break it off (it would be easy to do) or should I get a couple of large stainless steel hose clamps and wrap them around it on both ends to secure the shield? Any input would be appreciated.
Old Sep 23, 2012 | 05:06 PM
spittybays
Guest
Posts: n/a
Except for maybe the first 75 grand I have never had a heat shield and most defiantly never had a cat replaced that still had it. I guess its some gov. reg that they come from the factory with one. If you park on a big pile of dry leaves it could be a fire hazard. IMO rip it off and get rid of the rattle.
Old Sep 23, 2012 | 05:30 PM
abig84's Avatar
you can do either one. you can just hose clamp them down if you have them laying around. i dont think i have them on any of my trucks. worse thing they are going to do is give you a little bit of heat into the cab, but with carpet and insulation probably wont even notice it.
TripleBlackBlazer
68
Jun 26, 2012 11:49 PM
brandon1029
Feb 22, 2011 05:51 PM
Karcinagin
Aug 30, 2008 01:45 PM
Tippman7641
Aug 16, 2008 01:34 AM
sasquatchfound
Performance & Brainstorming
Aug 6, 2008 10:21 PM
