changing coolent
Old Jun 23, 2007 | 03:24 PM
eelding's Avatar
eelding is an unknown quantity at this point
Default changing coolent
i am replaceing my water pump, and seeing that i am draining all my coolant i would like to go with the green stuff not dex cool what do i have to do , besides replace dex cool with antifreeze
Old Jun 23, 2007 | 06:15 PM
Default RE: changing coolent
Flush the system (radiator, block, and heater core) with your garden hose and drain as best you can, then run a few gallons of distilled water through the block and radiator. When you go to fill the system with coolant, dump in exactly half the system capacity (~6 qts) with straight coolant (whatever your choice), then top off with distilled water. The distilled water doesn't contain any of the minerals that your garden hose may have, extending the life of the coolant.
I'd recommend going to the Prestone All Makes All Models Extended Life coolant.
redskins1
27
Mar 12, 2010 06:04 PM
antweber29
Dec 26, 2008 10:12 PM
lry040
Apr 15, 2008 06:25 PM
skyblazer
Jun 26, 2007 07:01 AM
eelding
May 10, 2007 09:54 PM
