Changing diff fluid. Do I need friction modifier
Old Oct 3, 2008 | 02:13 PM
  #21
WolfPack's Avatar
Default RE: Changing diff fluid. Do I need friction modifier
ZR2 isnt just a lift nor a package. It's a completely different frame, suspension, axles etc. Then there's the body styling on top of that.
The traction aid or w/e the package was called was a dealer option, and I think Bravadas had it standard? But if you have a ZR2 rear axle, that would be the 8.5' rear end (as opposed to non-Z blazers 7.625') with G80 gov-lock.
Old Oct 3, 2008 | 07:18 PM
  #22
punxweb's Avatar
punxweb is an unknown quantity at this point
May be a dumb question, is there an easy way of telling the two apart without opening it up? Bolt pattern?
Old Oct 3, 2008 | 07:20 PM
  #23
punxweb's Avatar
Found it.
[IMG]local://upfiles/9786/4E949654F17F44D1864834C5E5A7F560.jpg[/IMG]
Old Oct 3, 2008 | 10:49 PM
  #24
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
ORIGINAL: WolfPack
My '93 Bravada has the GT4 (3.73)/G80 (rear axle: positraction) combo and, looking at the manual, it looks like that was standard for the Bravadas. I don't know if it was a dealer or factory option for Blazers and Jimmys...
Old Oct 7, 2008 | 08:01 PM
  #25
Bad Ramer Jamer's Avatar
Bad Ramer Jamer is an unknown quantity at this point
You guys are a bunch of *** holes for saying I have a short attention span. I never said one damn word about a g80. You guys did, and made it very confusing. Ya,,,no means no,,,but not if we are talking about 2 diferant things *** hole. Thats the way you made it sound,,,like I had a g80.
So you all can kiss my ***.
Old Oct 7, 2008 | 08:08 PM
  #26
Hmm. Guess you do not want to stick around this forum. Nice outburst. See ya around.
You could have just ignored the comment as I am sure it was meant as a joke, not a stab, but whatever. I know mine was, but I am sure that it would have been better understood with a smilie or two. Good luck.
Another thing to note, typically when someone asks about requiring a friction modifier, it is because they have a locker or limited slip diff. It is very well known that an open differential requires nothing special. Yet another reason for including all information up front.
The post you replied to makes it sound like you are screaming at yourself. LMAO!!
Old Jul 13, 2009 | 08:55 PM
  #27
Nathan1991's Avatar
Nathan1991 is on a distinguished road
Hey guys, I want to service my front and rear differentials soon, I just got my 03 blazer LS 4 door, I checked the glove box and found the code g80 meaning i need no additive, I assume I dont need additive for the front as well??
I've never done this before so im a complete noobie, so to clearify
to drain I loosen all the bolts and take of the diff cover
clean the cover up and get a new seal
put the cover back on and fill it up with 80w90 gear oil through the fill plug
is that right?
also sorry if im asking in the wrong place I tried to find the tech article someone wrote but couldn't
Oh my mistake, I need an rtv sealant for the rear and the front diff just has a drain and a fill plug it appears
Old Jul 13, 2009 | 10:07 PM
  #28
There is a gasket available for the rear. RTV works as well, but you should not fill it up right away if you use RTV.
As far as for the front, there may or may not be a drain plug. Some diffs require you to suck the old gear lube out through the fill port.
As far as the friction modifier, there is no stock diff used in the s-series vehicle that requires any friction modifier additive. None. So you should be good with a 75w90 synthetic gear lube or conventional 80w90, whatever your preference.
This will get you through the rear axle:
Rear Axle Service
Old Jul 14, 2009 | 05:13 PM
  #29
Nathan1991's Avatar
awesome, I think I'm going to do it friday after work. Thanks for the help Kyle
BrinkDiamond
Mar 2, 2014 03:50 PM
jakem
Apr 22, 2011 12:34 AM
joey
Nov 27, 2006 11:32 PM
FJ40sRock
Engine & Internal
Mar 18, 2006 12:59 AM
BlaZeR FXB1581
Engine & Internal
Dec 11, 2005 10:15 PM
