Charcoal Canister prob/ Won't start
Old Mar 25, 2019 | 03:00 PM
joshwebster84's Avatar
joshwebster84 is on a distinguished road
Angry Charcoal Canister prob/ Won't start
Apologies if this has been covered, but I searched extensively before posting.
2000 Bravada, AWD auto, 177k mi.
I replaced my leaf spring shackles today, and in so doing, I removed the charcoal canister to better access the shackle bolts. When I was done, I reconnected everything exactly as it had been, but now the engine will not start, as though it is getting no fuel. I'm utterly baffled about what could be wrong here, someone please give me a clue.
Old Mar 25, 2019 | 08:36 PM
cleburne red's Avatar
I doubt messing with the charcoal cannister would cause a no start. Might give you an evap code, but the truck will run fine.
Is it possible you might have accidentally messed up the fuel pump wiring while you were under there?
Also, why do you suspect it's not getting fuel? Check spark, check fuel pressure.
Old Mar 25, 2019 | 08:45 PM
After letting it sit while the battery recharged after to many aggressive cranking attempts, I tried starting it with the purge solenoid unplugged, it cranked up, and seemed to be running rich. I plugged in the solenoid, and it was running great in about a minute. I don't know if there was an issue with the EVAP, if it just needed a ECU reset, or if the ghost of Ransom Olds just smiled upon me today. But now all is well.
Old Mar 25, 2019 | 08:59 PM
I vote it was the ghost of ransom Olds lol
Old Mar 26, 2019 | 02:12 AM
GeorgeLG's Avatar
Deus Ex Machina.
George
noe.boilard
Feb 11, 2014 05:20 AM
Foxcliffe
Jan 28, 2014 01:47 PM
HamToast
15
Jan 16, 2014 02:22 PM
95redblazer
Jul 9, 2009 12:28 PM
jpmccr
May 6, 2009 07:11 AM
