Charcoal Canister in the rear
Old Jul 4, 2009 | 11:48 AM
slk34's Avatar
slk34 is an unknown quantity at this point
Default Charcoal Canister in the rear
Hello,
I have a 2001 Blazer 4 door with 185k and I finally decided to replace the charcoal canister thinking it was broken because there was a bypass valve on one of the air hoses. Well, I replaced it and plugged it back up with out the bypass valve and the truck just wants to die. It constantly hesitates and backfires and you hear this suction noise coming from the gas cap. Once you open the gas cap it sounds like opening a fresh 2 liter of pepsi lol. There shouldn't be any suction coming through the lines I don't think and everytime I drive with the gas cap open, the truck runs fine. For now, I put the bypass valve back on until I figure out the problem. Would this be the Fuel pressure regulator or the Fuel tank pressure sensor? From what I heard about the vehicle, there is something broken on the sending unit preventing me to replace the sensor but I am not sure.
If anyone has any ideas it would be appreciated.
Thanks,.
Robert
Old Jul 5, 2009 | 01:29 PM
I would check to see if the EVAP purge solenoid is stuck open on the engine. It is located on the engine near the distributor.
mattadams1983
Apr 18, 2012 02:27 PM
wazzledoozle
Jun 4, 2011 05:14 PM
Squad-6
May 21, 2011 02:23 AM
puckrocker
Mar 2, 2011 02:01 PM
jphayes921
Apr 5, 2008 07:25 PM
