Precautions for removing Charcoal Canister
Old Apr 18, 2012 | 07:58 AM
mattadams1983's Avatar
mattadams1983 is on a distinguished road
Default Precautions for removing Charcoal Canister
I'm troubleshooting a P0440 CEL on a 2000 blazer 2wd 2door w/ 98K, and I've already replaced the gas cap, so I've been told to check the Charcoal Canister. I see there are 2 lines that say "flammable" on them, and two hoses.
Any precautions I should take when removing those, other than the obvious of don't smoke a cigarette while doing it?
Will fuel come out when I remove those?
How can I tell if the charcoal canister is the issue?
Thanks for your thoughts in advance. I'm not a expert mechanic, but resourceful, so any help is appreciated!!!
Old Apr 18, 2012 | 09:00 AM
pettyfog's Avatar
yeah.. no flames no sparks.
Dont be directly under it.. work at arms length.
Turn upside down, nothing comes out. Other than a little gas.
{Edit: should be no gas in healthy system}
blow through it.
Probably not oyur problem, if your didnt have previous issues, driveability problems
. Kinked lines, broken lines. inop purge vent, bad purge valve, broken front tank vent.. the list goes on. The code is cause by the PCM not seeing a vacuum signal from tank pressure sensor.. a LOT of territory.
Old Apr 18, 2012 | 09:48 AM
I have a hard time thinking its a kinked line or something, because I drive it very easy, and only to work and home.
Like you said, yeah, I haven't noticed any drivability issues. Pettyfog...would you start with the purge solenoid (by the ICM?) or the vent solenoid (attached to the canister?).
Old Apr 18, 2012 | 10:15 AM
pettyfog's Avatar
Havent done it read a lot. vent valve held open, easy to remove and test should close with 12v.
Here is the connector at the PCM.. pin 2 white wire ohm the valve, then check there to, should read 12v with key on.
Note.. the 12v is on the other side of sol coil from fuse ENG 1 underhood
note also pin 25. output of the tank pressure sensor
Take shop vac to fuel filler, vent valve line plugged. check reading.
Pin 2 of C3, {clr or gray or natural}.. is the purge valve control. should also read 12v with key on
Old Apr 18, 2012 | 10:29 AM
pettyfog's Avatar
And btw... dont start a new thread for every step
Mods, please merge to
https://blazerforum.com/forum/2nd-ge...e-p0440-70029/
Old Apr 18, 2012 | 02:11 PM
Tony H's Avatar
Tony H is an unknown quantity at this point
Old Apr 18, 2012 | 02:27 PM
There should not be any liquid fuel in any of the lines to or from the canister, or in the canister itself. As pettyfog mentioned, P0440 encompasses a ton of parts. Fuel tank, fuel tank pressure sensor, fuel pump module O ring, fuel filler neck, fuel fill cap, purge solenoid, vent solenoid, all wiring between all that stuff, the PCM, all vapor lines to and from the engine & canister, and the canister itself. P0440 is a malfunction in the EVAP system, not necessarily the purge solenoid or vent solenoid. If you follow this flow chart exactly as written, it will lead you to the problem: https://blazerforum.com/forum/diagno...plained-35145/
wazzledoozle
Jun 4, 2011 05:14 PM
Squad-6
May 21, 2011 02:23 AM
puckrocker
Mar 2, 2011 02:01 PM
slk34
Jul 5, 2009 01:29 PM
jphayes921
Apr 5, 2008 07:25 PM
