Check Engine Light Comes on when going up hills
RE: Check Engine Light Comes on when going up hills
tune up is a pretty common response to a misfire code. you could have a coolant pressure test done to see if youve got gasket issues, or you can do some investigating on your own. Check your coolant level, check your oil for signs of coolant/oil mixing, and you could even pull the plug in cylinder 1 (code would be P0301 by the way..p030x is misfire, the last digit indicates cylinder). If the plug is all nice and sparkling clean, youve been burning coolant and youre steam cleaning the plug.
good luck!
good luck!
As I said before, anything that was brought up prior to getting the codes read was/is pure speculation. You do not smell coolant leaking into the cylinders while you are driving down the road. I do not even know why it was brought up as a headgasket failure would have several other symptoms associated. More than likely, what he was smelling was the overflow bottle getting full and venting some coolant. Not good, but not the end of the world either.
I would definitely recommend a tune up as well as a cleaning of the radiator. Going up a long hill will produce some added heat for sure, but it should not result in your vehicle overheating. You definitely want to make sure that there is no debris stopping up the air flow through the radiator. While you are at it, you may want to throw a new radiator cap on it. It is cheap insurance against too low of a cooling system pressure. The rated 16psi cap will keep the system from boiling over too quickly. An old cap may not hold the system at 16psi, reducing the boiling point of the coolant.
ORIGINAL: swartlkk
If it was overflow, then shouldn't there be at least some splash or drip visible? But the OP said nothing visible. And after the first few overflows, shouldn't it eventually subside to a point where it's not overflowing regularly, even when working hard?
These conditions perfectly match head gasket issues I've had on two different vehicles. It's not guaranteed to be head gasket, but I'm still putting my money there. Misfire due to poor atmosphere or low compression in the cylinder.
Alright will do
thanks for all your help.
The only time I smell it is obviously when it Misfires.
I went up the hill going about 50 today staying around 2 - 3k RPM's
no check "engine light soon" came on, which was kinda nice.
I haven't gotten the "tune up" either yet. and it didn't smell after I got to the top as well.
I get my "tune up" next week apparently and I'll buy a new cap as well. then I'll go 65(speed limit) up that hill and let you know how it runs haha.
Since its a 98 with 114000 miles I'm betting its time for the problems to start coming.
We tried to pull a pretty big trailor with it and the radiator cracked.
Which end were you pulling the trailer with???
lol
lol
lol what do you think.. the hitch in the back
it was to much pressure on the old thing.. 300+$ later..
Sorry, I couldn't resist.
ORIGINAL: abadinalbany
Sure ya do. Not as obvious as if you're behind the car, but you most certainly can. I know I have.
Skitzoape
07-03-2012 05:46 PM
scott_wheels
01-26-2010 05:49 PM
chrisjanicki01
09-04-2009 05:34 AM
