check gauges light comes on and humming noise aswell.
Old Jun 5, 2010 | 04:53 PM
bulldogauto's Avatar
bulldogauto is on a distinguished road
Default check gauges light comes on and humming noise aswell.
Hey everyone im new to blazer forums so lets see if someone can help me out. Iv got a 2001 chevy blazer v6. Iv had this vehical for quite awhile and iv with basic maintenece it has held up really well. Just recently the check gauges light comes on and will either stay on for awhile or it will go out and periodically come on again and sometimes flash. This is going along with a very hard to hear humming noise coming from around the area of the throttle body. if anyone has any ideas let me know thanks.
Old Jun 5, 2010 | 06:08 PM
1998MSO's Avatar
1998MSO is on a distinguished road
And are the gauges reading OK?
Old Jun 5, 2010 | 06:41 PM
yea nothing unusual!!!
Old Jun 5, 2010 | 07:39 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
The flashing check engine light means the engine is misfiring badly enough that damage to the catalytic converter is possible. The humming noise could be a stuck Idle Air Controller motor or it could be you have good hearing and you can hear your injectors working. Find an auto parts store that'll read the codes out of the computer and report 'em.
Old Jun 5, 2010 | 07:47 PM
Its not the check engine light, its the check gauges light. Iv had the car for almost 8 years and the humming is definetly new. Iv done all work on the car and even the DTC codes say that there is nothing stored in the pcm.
Old Jun 5, 2010 | 10:38 PM
blazer_in_ky's Avatar
blazer_in_ky is on a distinguished road
ive got a 97 blazer and mine hums when it adles and mine is the pcv valve.
you might want to check that too.
Old Jun 6, 2010 | 06:17 PM
RonJon's Avatar
Only 3 things are supposed to turn that light on, low oil pressure, engine temp over 248°, or 3 second bulb check when you turn the key on. If it was a bulb check you'd see other lights as well. Check the connections to your oil pressure sensor (top of the motor in back of the distributor) and engine temp sensor (driver side head about 3/4 of the way back by the exhaust manifold). Might be an intermittent fault that's too quick to show up on gauges but long enough to trip the instrument cluster to turn that light on. Or might be the dash cluster has got the flakiness.
Old Jun 6, 2010 | 10:12 PM
thanks ronjon im ganna check those when i get off work and ill report back
Old Jun 28, 2021 | 10:41 AM
GrandpaDan's Avatar
GrandpaDan is on a distinguished road
Hey Bulldogauto, you've been at work for 11 years now. Hope they let you off soon so you can do those checks and report back to us!
Skitzoape
Jul 3, 2012 05:46 PM
scott_wheels
Jan 26, 2010 05:49 PM
chrisjanicki01
Sep 4, 2009 05:34 AM
88Silverado
Jan 15, 2009 12:11 PM
Kingman1901
17
Nov 9, 2008 04:44 PM
