Check out this head gasket! ! ! ! ! !
Old Jul 21, 2013 | 12:00 PM
palmer96's Avatar
palmer96 is on a distinguished road
Talking Check out this head gasket! ! ! ! ! !
So i have put up a few posts recently about random misfire codes then i did a compression check and found out that #3 and #5 were about 60 psi. This is what i found when i pulled the head off!!!!!! I have never seen a head gasket this bad before.
Attached Thumbnails Check out this head gasket! ! ! ! ! !-img_20130720_160141_353.jpg
Old Jul 21, 2013 | 12:02 PM
247monster's Avatar
naa thats still good for another 100k lol
Old Jul 21, 2013 | 01:26 PM
chris015's Avatar
I may be wrong,but i dont think thats the factory gasket set. Did you buy this used? maaybe the person before you didnt torque it down correctly.
Old Jul 21, 2013 | 03:06 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
I thought the same thing on the torque,
Old Jul 21, 2013 | 04:30 PM
palmer96's Avatar
ya i bought it used. That is a fel-pro gasket so i am also thinking improper installation. the blazer also has 211K on it, but i dont know when this gasket was last changed.
Old Jul 21, 2013 | 06:27 PM
chris015's Avatar
Hmm. have the heads checked for cracks. If you have a crack where the headgasket is broken between cylinders that could be the reason that failed.
Old Jul 21, 2013 | 07:29 PM
palmer96's Avatar
So today i got to take it on a test drive so i know its all good. I couldnt do it last night because i had wayyyyy to many beers. When i pulled back into the drive and was doing a once over, the water pump took a ****. the weep hole was pouring. I just can't win with this thing.
Old Jul 22, 2013 | 09:16 AM
chris015's Avatar
lol thats the way it happens. its a easy job though. pop off top rad cover,fan,4 bolts and a hose. then replace and bleed. Done.
limited edition 1
Jan 27, 2023 11:07 AM
mylittletonkatruck
Mar 7, 2012 02:04 PM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
