clicking behind glove box
Old 05-06-2008, 09:48 AM
greenlantern77 is an unknown quantity at this point
Default RE: clicking behind glove box
I have the same problem on a 99 2 door zr2 blazer.
Does anyone know if the steering wheel/air bag have to be removed to replace the multi-function blinker/hazard/cruise switch (any additional details on the process of removing/installing this switch would also be greatly appreciated)?
Has anyone ever taken the faulty one out, examined it,and found a fixable problem, fixed it and put it back in successfully (it would be great if i could avoid paying the 200$ for the new switch)?
Thanks
Old 05-07-2008, 11:59 AM
it looks like there are only 2 star heat bolts holding it on, is that right? Any ideas on how to get the side bolt out, there is no room behind it?
Old 05-08-2008, 07:25 AM
any help from anyone who has replaced one of these would be great. I have gotten the multi disconnected from the column but the wires disappear into the dash, and are tied to other wire bundles and etc and the multi costs 200$ so this is definately not a easy fix that is done with fairly little disassembly and not a lot of $$$.
Where do the wires end and how do i get to them?
Old 05-08-2008, 07:38 AM
just another note but when i can hear the clicking noise, none of the dash blinkers are flashing but if i slightly depress the hazard the right turn signal indicator on the dash lights up (blinking).
i am also posting on
https://blazerforum.com/m_116896/mpa.../tm.htm#159826
Old 05-12-2008, 11:25 AM
dont worry about it, i figured it out myself
Old 05-12-2008, 11:32 AM
fun2b1's Avatar
fun2b1 is an unknown quantity at this point
would be GREAT if you told us all how you resloved your dilema:-)
Old 05-12-2008, 11:43 AM
Based on the other post, he was having difficulties with the removal of the multifunction switch (see why double posting is bad...).
I believe he figured out how to remove the mutlifuction switch and that he repaired the problem by replacing it as suggested.
Mike F in Nebraska
05-10-2014 07:32 AM
dj00140
12-14-2011 01:58 AM
MT123
03-09-2010 04:27 PM
Buschkj24
05-24-2009 09:50 PM
PiTRiFF
01-15-2009 06:59 AM
Quick Reply: clicking behind glove box
