clicking noise
Old Feb 23, 2012 | 10:35 PM
turbotype87's Avatar
turbotype87 is on a distinguished road
Angry clicking noise
Hello all, I have a problem with my 2002 chevy blazer ZR2 Vortec 4.3 litre engine. It seems to be only at start up for about 30 seconds and then goes away? When it is warmed up it doesn't make any noise. It's driving me crazy. I gave changed the oil three times in a week and substituted 1qt of oil for a quart of marvel mystery oil. The noise went away for about three days and it started again? So i changed it again thinking it maybe a lifter sticking. I tried a can of Seafoam as suggested by a friend. Same thing happened again the noise went away and came back 3 to 4 days later. Any help will be appreciated. thanks Scott in CT
Old Feb 24, 2012 | 08:56 PM
Esty's Avatar
Esty is on a distinguished road
I use Trans. Fluid my self when I have a lifter problem
But you cant leave it in
I use 1 quart Then I start it up and let it warm up then I jump it up on the Highway and run it hard for 1 exit then 1 exit back
then I dump the oil and use new oil and filter
Why Trans fluid
Trans fluid is a oil but it is a cleansing oil it will clean out the little ports and holes and stuff it will also help pump up them lifters
But it also swells up the seals because there not made for trans fluid that is why you cant leave it
That is just what I do
some people use to use kerosene (bad Idea) that will put extra unwanted miles on your bearings
Good luck
Old Feb 25, 2012 | 10:16 AM
Lower intake manifold gaskets like to leak coolant on these things. If they leak internally, (very common) the coolant will dilute the oil and cause lifter noise on cold start ups. At first it's only for a second or two, usually on only one, sometimes two lifters but as more coolant gets into the oil it affects more lifters and the ticking lasts progressively longer during warm up. A cooling system pressure test, both hot and cold, will determine if there's a leak. If you need to keep adding coolant, and can't find a leak, this just might be the problem.
Piston slap is also fairly common on the 4.3L and it has pretty much the same symptoms except the noise is a deeper tone, lower in the engine. Sounds almost like a bad rod bearing but not as harsh, and only does it when increasing RPM, unlike lifters that tick all the time.
Old Feb 26, 2012 | 11:18 AM
blazinbman's Avatar
blazinbman is on a distinguished road
i agree with captain hook, gm's are notorious for piston slap, once they get up to operating temp it goes away hope you figure out the issue
Blazinflaboy
Jun 22, 2010 09:03 PM
p72lwor
14
Jan 8, 2010 06:16 PM
dion21379
Jun 20, 2006 05:35 AM
mandi
May 3, 2006 11:02 PM
blazergirl15
Aug 28, 2005 11:17 PM
