Clicking or taping sound from rear?
Hello. I have a 95 4.3V 4x4. When I push on the gas aggressively I can hear a clicking or taping sound coming from what sounds like the rear. A buddy and me pulled off the differential cover to have a look and all is good. Wire brushed it, painted, put it back on and refilled it with new fluid. Is this coming from the drive shaft? It is also starting to do when it changes gears, like when I'm trying to get on the highway. Is this an easy fix? Thanks in advance for any help.
sounds like the rear driveshaft u joint is going bad mine is doing the samething
you might need the joints in the drive shaft . go under your truck and shake your drive shaft . if its got play you need to replace the joints
I will check it tonight when I get home. Thanks!
DaddysBlazer
08-27-2011 12:42 PM
Blazinflaboy
06-22-2010 09:03 PM
rastoma
03-04-2010 08:34 AM
Buschkj24
05-24-2009 09:50 PM
chevblazer02
03-06-2007 04:49 PM
