clutch fan question
Old Mar 15, 2013 | 06:59 PM
curtis450r's Avatar
curtis450r is on a distinguished road
Default clutch fan question
I have a 97 ZR2 blazer and the clutch fan keeps engaging while im going down the road. Is this normal? The coolant temp never gets over 170ish and the enging and trans are both operating normal just dont know why the clutch fan keeps engaging any help would be appreciated thanks.
Old Mar 15, 2013 | 09:57 PM
Twip's Avatar
mine is doing the same thing right now and i just dont feel like fixing it. the thing with the fan is that it has a thermal-rotational clutch in it. when the motor gets too hot and the fan is spinning slow enough, it will engage until you get around 2500 rpm where it normally disengages. what has happened to yours, and mine, is that the thermal part of the clutch has gotten worn out. too many heat cycles. the only way to fix it is to change the clutch. i believe that they are around 50-60 dollars. i havent even checked. but they arent that hard to change.
and 170?? that seems low. you should have a 195* thermostat in it. you should change that while you are doing the fan. thats what the stock operating temp is. and having it run cooler doesnt have any horse power or torque advantages. you need the heat to properly burn the fuel and have the cats and other things get the to right temp. including O2 sensors.
Old Mar 16, 2013 | 06:35 PM
curtis450r's Avatar
Thanks for the imput. I thought it was running a little on the cold side but i just bought it a couple weeks ago so i will add a thermostat to the list of things to fix. Im currently trying to put in new seals in the transfer case so my transmission fluid will quit leaking into it.
Old Mar 16, 2013 | 10:23 PM
cleburne red's Avatar
Mine shows about 170-180 on the gauge, but when viewing live data on my scan tool, it's usually closer to 195 (which is what thermostat I have in there). I figured the gauge was just not quite calibrated.
gitch93
Jul 23, 2013 08:06 AM
cheesequaker
Apr 25, 2012 01:44 PM
85kulan
Oct 4, 2011 09:51 AM
MintyMadness
Jul 13, 2011 12:37 AM
2002XTREME
Mar 23, 2008 05:12 PM
