" co" codes 6 of them
Old Jul 18, 2013 | 10:02 PM
blazzer1's Avatar
blazzer1 is on a distinguished road
Cool " co" codes 6 of them
co265,co236,co237,co281,co222,co226 all abs codes , i know i have a rt rear brake problem. But wth. And i also have a co128 low coolent temp. Yes i pulled my t-stat so it would run cooler in the sand. Any comments ?? Would be help full. Thanks larry r
Old Jul 19, 2013 | 06:29 AM
rriddle3's Avatar
The first 6 codes you mention are brake codes. Check the ABS sensors on the wheels. Clean them and check the ground wire connections.
The last code you mention is a low brake fluid warning code. For it to be low coolant temp code it would be P0128, not C0128. Plus, if you removed the thermostat then you already know why you would get a low coolant temperature warning.
In all the codes the second character is a '0' (zero), not the letter 'o'.
abadinalbany
Apr 16, 2011 11:31 AM
stanitis
Nov 27, 2010 11:10 PM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
