Oil cooler lines-radiator
Old Jul 18, 2013 | 09:42 PM
Impact's Avatar
Impact is on a distinguished road
Default Oil cooler lines-radiator
I know this is a common problem with the blazer and mine were leaking so time to change them (radiator to housing). Now both lines are leaking real bad at the radiator. Is there a trick with the clips or something that im not doing right. Thanks
Old Jul 18, 2013 | 11:58 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
I wouldn't say that there's necessarily a trick to it. You have to make sure that the lines are completely seated in the inlets before you put the clips in. I just did the job a couple months ago on my Jimmy and it went well and was pretty straight forward.
Check the lines again where they go into the radiator. There should be no motion.
Old Jul 19, 2013 | 09:42 AM
Impact's Avatar
I replaced both the fittings on the radiator and no leaks now. Thanks for the help
MWS1994
May 12, 2014 03:26 AM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
NYC86ZC
Dec 12, 2010 08:21 AM
Jetfixer
Jul 11, 2006 05:02 AM
