Code P0301
Code P0301
I have a '96 Blazer. It had a leaking intake manifold gasket so I replaced it. Put everything back together and now the truck is running rough and code P0301 pops up. Please help!!
this should help you out
https://blazerforum.com/forum/diagno...4-5-6-a-35153/
follow the steps and get back to us
Since you removed the distributor during the intake manifold gasket, I would suspect a timing problem.
I would run through the EDI Engine Timing procedure to make sure that it is set properly. You may need to set the CMP Retard as well which requires a scan tool capable of displaying the CMP Retard.
I Moved it about 50 feet and my buddy said it sounded like a machine gun.
bizutch
01-01-2010 01:09 PM
