Code reader will not connect to computer it does light up and try to scan
I jumped the wire from just behind the computer dk green to purple on splice pack (that would be like jumping purple to dk green) and no communication the car starts (although it kicks back and then will restart just fine ) and seams to run ok short drive and it shifted fine the bat light is on but gage shows about 12 and jumps to 14 when started also abs security air bag and low fuel light is on i am thinking computer but don't know could a computer cause all this?
thanks john
thanks john
Follow what the guy does in the video in post #6. If you get nothing even with the comb out after trying all the pins then yes go to the connector at the engine computer and try the dk grn class 2 wire there. Make sure that the truck is running for all of this.
George
George
i got a scope and found a data signal and had a signal on the data bus but no communication to scanner what are the 4 wires to obd2 connector i assume 12v and ground and data is there a data ground also? anyway the engine runs good but it kicks back on first start it will stay running good if you turn it off after it runs even just 10 seconds it starts just fine
