compatible starters?
The following part number are Lester Part Numbers, you can use the following starters:
6407 earlier SD 255
6449 SD 260 same as above but higher torque
6485 SD 260 second generation of the 6449
6495 SD 260 second generation of the 6485
You can also use if it fits 3510 or cold weather starter 3733. It is alway best to replace with the unit that was designed for your vehicle but of all the choices the 6449 is your best application.
6407 earlier SD 255
vetteandblazerman
Sep 15, 2011 11:48 AM
donnieb83
Jul 15, 2008 07:41 PM
