Convert disc to drum brakes 2000 s10 jimmy
Old Apr 23, 2019 | 10:31 PM
chronamyd's Avatar
chronamyd is on a distinguished road
Default Convert disc to drum brakes 2000 s10 jimmy
Hi. Does anyone know witch backing plates to use to convert a rear disc brakes to drum brakes on a 2000 S10 Jimmy 4x4. I am putting the rear end in my 54 Chevy 210 , theirs no room for the calipers as the frame is not designed for it.(clearance problem). Also witch drums do I need.
Old Apr 24, 2019 | 07:26 AM
mr.vls's Avatar
Any backing plate from a first gen drum brake will work. However the axle mounting flange is different between the drum and disk brake. I did the reverse on my 89 S15 Jimmy. I had to cut the axle flange square for the disk brake conversion. I used 2000 Bravada parts for my drum to disc conversion. The drum brake axle flange has the mounting for the wheel cylinder and the hold down for all the springs. The pic shows the drum axle flange before I squared it off for the disc brake conversion.
Old Apr 24, 2019 | 12:19 PM
El_Beautor's Avatar
You're probably better off just grabbing an axle with drums from a Pick n Pull if you have one near you.
Old Apr 24, 2019 | 09:21 PM
chronamyd's Avatar
I have a 373 posi I don’t want to loose it. I will figure it out, I was looking for an easy way out. Thanks Dwight
Old Apr 26, 2019 | 08:13 PM
Just swap the gears in the axle when you swap it in...
K5fhun
Nov 20, 2018 05:11 PM
alangri
Sep 16, 2013 11:29 AM
Chesnuts5
Oct 24, 2010 12:44 AM
AN7967
Oct 23, 2009 04:19 AM
Blazar1996
Tires and Wheels
Sep 10, 2006 04:57 PM
