Need Help! Converting From Drum Brakes to Discs
Old Oct 22, 2010 | 07:08 AM
Chesnuts5's Avatar
Chesnuts5 is on a distinguished road
Default Need Help! Converting From Drum Brakes to Discs
How expensive is it and is this something acheieveable for an amature car enthusiast??
Old Oct 23, 2010 | 12:50 AM
69chevelle's Avatar
69chevelle is on a distinguished road
disc brake conversion..
it's been discussed, use the search feature
Old Oct 23, 2010 | 10:33 AM
65longroof's Avatar
65longroof is an unknown quantity at this point
Wink
It may be easier to do the conversion by changing the entire rear axle. Thats what I did and it was way easy, would even be pretty easy for a novice. What year blazer do you have?
Old Oct 23, 2010 | 10:02 PM
69chevelle's Avatar
pull axle shafts out, unbolt backing plate/mounts. mount on disc brake stuff, slide axle shafts back in.
easier then swapping rear axles, then you can change your fluid while your at it. as well as bearings and seals
different proportioning valve and possible master with disc brakes though.
Old Oct 24, 2010 | 12:44 AM
blazerpower's Avatar
blazerpower is on a distinguished road
poertsch
Apr 23, 2016 01:05 PM
yarinzim
Mar 1, 2013 12:21 AM
4good
Mar 16, 2011 11:07 AM
dimmuborgir6nik6
Dec 16, 2007 07:06 PM
Marcin
Nov 13, 2006 05:17 PM
