rear drums to disc conversion using oem parts
Old Nov 15, 2018 | 10:54 PM
K5fhun's Avatar
K5fhun is on a distinguished road
Default rear drums to disc conversion using oem parts
Aloha,
Looking for any info on gm drum to disc swap utilizing oem junkyard parts.
94 K5 Blazer
Old Nov 20, 2018 | 05:11 PM
mr.vls's Avatar
I converted my rear drum to disk using junkyard and new parts. This was on my 89 S15 Jimmy. The major points was a follows. 1) The mounting tab on the donor axle for the hard line to brake hose on each side needed to be chiseled off and welded them on to my axle. 2) The mounting plate on my existing axle needed to be squared off and 2 holes drilled for the disc backing plate. 3) The brake calipers needed to be shimmed slightly to center the calipers on the rotors. I pulled R/L brake lines, mounting tabs, backing plates, calipers, hoses, rotors and all the hardware. I purchased Shim kit on ebay and I used the junkyard calipers as turn it items for rebuilt calipers at advanced auto. Below is my original Write up.
https://blazerforum.com/forum/1st-ge...on-done-94933/
chronamyd
Apr 26, 2019 08:13 PM
89rustyk5blazer
Dec 6, 2015 09:31 AM
c5demon
Nov 27, 2013 08:33 AM
packrat1969
Sep 2, 2013 10:08 PM
tooth_dr
Jul 3, 2013 05:32 AM
