converter clogged??
Old Jan 22, 2011 | 08:07 PM
old skool luvr's Avatar
the way this thing is acting.........it almost sounds like an IAC issue on the earlier 4-3's.
Old Jan 22, 2011 | 11:29 PM
redDragon96's Avatar
redDragon96 is on a distinguished road
yeah i thought that might be the problem so i cleaned the passageway and still no change.the iac is relatively new. is it possible that it might be bad again? idont really want to just go buy a new one and it not change anything...
Old Jan 23, 2011 | 01:13 PM
blazinloud's Avatar
well theres air entering the engine somewhere, you know that. so the best guess would be either something wrong with the TB or theres a vacuum leak.
Old Jan 23, 2011 | 02:46 PM
i appreciate everyones input and help but im still lost. so i think im going to go get a new iac and try that. could there be something wrong with the tb? the back of the butterfly is pretty dirty.
Old Jan 23, 2011 | 04:30 PM
blazinloud's Avatar
yes, if it dosent shut all the way.
Old Jan 23, 2011 | 05:46 PM
ok the tb is closin all the way... so i think i will go pick up a tb gasket and new iac, clean the tb as best as possible and see what happens..
i have a book of records of stuff done with the truck and the iac was replaced on 8/7/2010. the throttle body was also cleaned at the same time.(doesnt look like its ever been cleaned). i dont have the sixty bucks for a new iac and i cant find the reciept so im not gettin a new one yet. but i will go get a tb gasket so i can take that off and clean it. i will come back later and report what happens.
Last edited by rriddle3; Jan 23, 2011 at 06:02 PM. Reason: COMBINING CONSECUTIVE POSTS
Old Jan 23, 2011 | 11:41 PM
if your IAC was just replaced last Summer, i can't see it being a cause to the problem. but it would be worth taking it off to inspect it, while you're cleaning everything.
Old Jan 24, 2011 | 01:16 PM
i didnt think that the iac was the issue. although i do agree that it does sound like an iac issue. i am hoping to get around to pulling it apart tonight when i get out of work.
Old Jan 25, 2011 | 09:58 PM
alright i jus got done cleaning my throttle body. i replaced the gasket and cleaned everything up real good. i only started it, havent drivin it yet but it seems that the problem has been resolved. it revved up pretty high when i started it, i then realized that i forgot to put the vacuum line on the back of intake tube but i put it on, put the truck in drive and it didnt rev up like it was. i will drive it in the morning and come back on to report the results. thank you everyone for your help!
Old Jan 25, 2011 | 11:28 PM
just remember to turn the key off if she starts to get out of hand.
hopefully the next thing we hear is............."she's golden!!".
