converter clogged??
Old Jan 31, 2011 | 10:12 PM
  #31
old skool luvr's Avatar
what about your local parts stores? a couple of the major stores up here (Canadian Tire & The Parts Souce) have a loan-a-tool program that lets you have borrow tools for free, provided you bring it back within 72 hours.
i'm sure your O'rilley's & Pep Boys must offer somehting similar.
Old Feb 1, 2011 | 01:30 PM
  #32
JESSEGOTTA 99 4X4's Avatar
JESSEGOTTA 99 4X4 is on a distinguished road
I soaked my throttle cables (at the TB) and the sides of the butterfly where it connects to the tb and it seemed to fix it.
Old Feb 3, 2011 | 07:38 PM
  #33
redDragon96's Avatar
redDragon96 is on a distinguished road
alright i got my surgery done and think i can get my hands on a fuel pressure tester. does anyone know what my fuel pressure should be and where do i hook up to test it?
Old Feb 4, 2011 | 08:42 PM
  #34
there's a schrader valve behind the throttle body. remove the black cap, screw/slip on the fitting from the tool.
supposed to be 55 to 60 psi to start. i think 50 while running is fine, and @ WOT it should be @ 66. also, pressure should jump instantly when the throttle is jabbed.
just a little FYI, my Dad's '98 'Burb was (still is) acting a little like your truck. only 1/5th throttle to drive, any more & it falls flat on it's face.
has good start-up fuel pressure (56 psi) and drops to 52 when running. but will not move more than 1 pound when the throttle is floored (even when parked) so his pump is in need of replacement.
oh yeah, it's noisy as hell too.
Old Feb 5, 2011 | 03:39 PM
  #35
alright i will look for it. thank you. thats interesting on his fuel pump. my fuel pump is pretty noisy but thats by my standards.
Old Feb 7, 2011 | 04:19 PM
  #36
ok i hooked up and checked my fuel pressure. at key on it was at 60. i waited a min to start it while i was waiting the pressure slowly dropped to 57(not sure if this means anything). when i started it up the presure was at 54. it jumped pretty fast when i jabbed the throttle but never went over 60psi. at most i think it was 58 or 59.
Old Feb 7, 2011 | 10:05 PM
  #37
ok, but what about @ WOT? was 60 the highest it went?
Old Feb 9, 2011 | 11:21 AM
  #38
ya at wot i saw 59 maybe 60.i thought maybe i had to hold it wot for a sec so i did that and still the same
Old Feb 10, 2011 | 01:01 PM
  #39
i was cruisin the forums and found some stuff about splice pack 243... and to me it sounds like this also might be a possibilty.. do you guys agree? its really cold here and i dont have the luxery of a heated garage so i want some opinions before i freeze off my man hood and end up wastin more time. thanks
Old Feb 10, 2011 | 11:42 PM
  #40
yeah, i've looked into that already for Brad's (zedartwo) truck. you can read through his build thread if you want (this was just last month), but after spending more than an hour messing with that splice pack, it really didn't change anything 110% on his.
i also put a new cap on his truck while i was @ it, since he didn't change it when he did a tune up last.
since his truck was acting up like my Dad' 'Burb was (is), i kinda pointed out the fuel pressure issue to him after i had a chance to go @ my Dad's 'Burb. his fuel pressures are what i mentioned in post #34.
