converter clogged??
#51
thats good to know. a friend of a friend can help me out with the scanner. what sensor did you end up having to replace?
#52
Fuel tank pressure sensor. Located on top of the fuel tank on the pump assembly. Yours is acting just like mine did. The code mine threw was TPS input low. I dont remember what the number was. SWARTLKK is right! dont replace the sensor unless you go through the troubleshooting sequence. I threw a TPS code but the sensor wasnt bad.
#53
i also had the tps code but i recently replaced it and its now gone. i am gunna try to get it hooked up to a scanner tonight, if i do i will post results.
#54
My TPS input low code popped up as soon as the truck started to lose power going down the road.
#55
welll.... i still havent gotten to do anything with the blazer... is there a way i could test my fuel tank pressure sensor without getting it on a scanner??
BlazeRDA
12-11-2007 04:54 PM
filtalr
10-04-2007 12:20 AM
