Coolant leak after replacing LIM gasket
Old Nov 22, 2010 | 06:05 AM
stlwaco's Avatar
stlwaco is on a distinguished road
Default Coolant leak after replacing LIM gasket
I was getting a leak down the right side of the bell housing. Figured doing the lower intake would correct the issue. After putting it back together, it still is leaking but I can not see where from. Anybody else come across this and what did you find was the issue? Heater hoses are not leaking. I guess the only other things it could be are a cracked intake manifold, cracked head, or a blown head gasket. But it doesn't run rough or blow white smoke. I'm desperate. Any help would be appreciated.
-Mike
2003 ZR2
Edit: Added dye to the cooling system. Ran the black light between the firewall and engine. Seems like it is going to be the head gasket on the left bank. Getting a glow from that area. At least I hope it is just the gasket...
Joey1986Z
Jun 23, 2014 11:09 AM
Snowgoat
23
Dec 17, 2013 09:15 PM
Little Roober
Sep 30, 2012 07:31 PM
ckirv
Feb 19, 2012 12:07 PM
Charder
26
Aug 12, 2011 04:33 PM
