Coolant and Tank Hose
Old Nov 26, 2007 | 01:33 PM
jbreno's Avatar
jbreno is an unknown quantity at this point
Default Coolant and Tank Hose
After doing a search here, I found this thread, but the correct answer was not clear...
https://blazerforum.com/m_68378/tm.htm
The hose shown is this picture was not connected to anything. Is this an overflow, or should it be connected to my radiator? There is some fuild left in the tank, but it is not much. Certainly not to the "hot" level line.
Can someone please help?
[IMG]local://upfiles/7420/B942A587C7F14E1687E430CED609F7E8.jpg[/IMG]
[IMG]local://upfiles/7420/D543260DDC0747AF85F32C3308898F97.jpg[/IMG]
Old Nov 26, 2007 | 01:54 PM
Default RE: Coolant and Tank Hose
That hose is the vent/over-flow and should terminate somewhere down near the frame rail. If you follow the hose attached to the radiator right next to the cap, it should connect to the overflow tank.
How is the level of coolant in the radiator? If the radiator is low, it is possible that the radiator cap is bad. Even if it is at the proper level, a replacement cap is good preventative maintenance.
Monica Joplin Mitchell
Feb 13, 2013 09:24 AM
86TransAm
14
Dec 13, 2011 07:46 PM
wjdjake
Jul 17, 2011 02:06 AM
rob1621
Apr 3, 2008 08:55 PM
ratwell
Dec 16, 2007 09:50 AM
