correct jumping method
Old Sep 1, 2008 | 01:29 AM
2klt's Avatar
2klt is an unknown quantity at this point
Default correct jumping method
Okay, not sure why the brain lock, but the proper method for jumping the ac comp. for ts. is fused wire across the l.p. sw., or fused wire from bat. 12v.+ to green wire on l.p.sw. conn. and another from ground to other side of connector? I tried puting fused jumper to l.p. sw. but blew fuse. BLAM!
Old Sep 1, 2008 | 07:53 AM
2klt's Avatar
Default RE: correct jumping method
well i feel better knowing that there are at least 9 people that are like me and don't know the answer to my question as far as the proper way to apply 12v. to the circuit I am asking about... This sure has been a testy labor day...
Old Sep 1, 2008 | 09:09 AM
Was it really necessary to post this rediculous reply to your original post a mere 6 hours later?? Come on. Such impatience even considering that you posted at 2:29AM EST. And it is quite possible that those 9 people that looked knew that this very information was posted before... Search works wonders man. Help yourself!
NO, you DO NOT apply 12V to the low pressure switch wiring. Only apply fused +12V and ground to the clutch connector itself if you are jumping it there. If you are jumping the low pressure switch, then a wire will suffice.
Old Sep 1, 2008 | 11:49 AM
2klt's Avatar
No, i suppose not. I do apologize to the board for my remark. It has been a very bad weekend and in general just lately altogether. No exccuse though.
Plus the fact that I have been hassling with this damn truck's ac and horn for not weeks but months. On top of all that, I kept getting shot at but missed and finally sxxt at and hit.
I'm sure if I would have just stopped and thought it through, I could have figured that I should not apply 12v. to an already charged circuit, just closing it would suffice. However, Ifif do need to jumper the low pressure switch, how long can it be left jumped?
Again, an apology to the group
Old Sep 1, 2008 | 02:07 PM
For testing purposes, you can leave the low pressure switch jumped until you are finished determining what the problem is. It should only need to be jumped long enough to ensure that the appropriate charge is in the system or charge it to the appropriate pressure.
j00blazer
Lowering Tech
Mar 16, 2010 01:19 AM
ravenhurst
Feb 16, 2010 05:53 PM
elementalnature
Aug 25, 2008 08:42 PM
