Could be a faulty ICM ?
Old Aug 4, 2011 | 03:25 PM
n_markov's Avatar
n_markov is on a distinguished road
Question Could be a faulty ICM ?
Hi guys,
While driving and stopped my Blazer'98! Tried to restart, run hard and started to fall to 600 rpm and the engine off, try this lot. Fuel reaches the engine.
What could be the problem ..... ICM (ignition coil modul), thanks in advance
During the weekend will hold a test of this LED module http://easyautodiagnostics.com/gm_ic...agnostic_1.php
Old Aug 4, 2011 | 03:35 PM
You say that fuel reaches the engine, but at what pressure? These engines require >55psi and the pressure should remain above 50psi for 10 minutes after the pumps shuts off. You need to test the pressure with a fuel pressure gauge.
Testing the ICM & coil wouldn't hurt, but typically these parts have heat/load dependent faults that may not show up testing the unit cold.
Old Aug 22, 2011 | 09:16 AM
n_markov's Avatar
forgot your hat informiram.Distributor cap problem was!.Substituted was 2000 km (1 1 / 2 months). was just a defective
BlazeOn
68
Feb 7, 2019 10:24 AM
01lsok
Jan 29, 2011 02:38 PM
2wings4me@ntelos.net
Dec 29, 2010 11:25 AM
83GMC-JIMMY
Oct 6, 2010 09:06 AM
devestator_x
Dec 26, 2007 10:08 AM
