Possiable Faulty Fuel Sending Unit/Pump
Old Jan 29, 2011 | 09:20 AM
01lsok's Avatar
01lsok is an unknown quantity at this point
Question Possiable Faulty Fuel Sending Unit/Pump
Here is the general diognostic: 2001 4WD Blazer
1. The fuel guage has been on the frits for a long time. (didn't fix it because it was not completly broken).
2. Went to start the blazer and no fuel prime sound with ignition on and engine turns over.
3. Swaped relay switch with the fog lamp because there the same. Back to number 2, same result.
4. Didn't notice security light or open fuel pressure check valve, will have to double check.
5. Curious if pump can be checked by finding a short at the relay switch with a multi-meter.
Old Jan 29, 2011 | 09:41 AM
rriddle3's Avatar
Follow the steps and instructions in these two threads to help isolate the problem.
96+ Fuel System Diagnosis
98+ Fuel Gauge Diagnosis
Old Jan 29, 2011 | 02:38 PM
01lsok's Avatar
Went back to the parking lot to verify a couple of things. Just happen to have a wiring schematic. With the battery fully charged, the Oil pressure gauge reads and the security light goes off after 2 seconds. This eliminates any ignition problems because it completes the circut. I should check to see if there is power going to the sending unit, but this requires droping the tank anyways.
Checked in with one of my mechanic friends and his asessment was the same. If the relay is not the problem then it is the pump. Since its been so cold that fuel pumps are breaking, (he had to change several this week).
hypertek
Sep 21, 2011 08:41 AM
ineedspeed7
24
Jan 11, 2009 09:31 PM
JayPerpich
Dec 20, 2008 04:34 PM
Poke626
Jul 8, 2008 08:08 PM
dusted800
Jan 27, 2007 10:16 PM
