Couple Questions from a new owner
Old Mar 5, 2011 | 09:24 PM
ilovedonuts13's Avatar
ilovedonuts13 is on a distinguished road
Default Couple Questions from a new owner
I have a couple questions regarding my 96 2wd s10 blazer...
1) Only after the engine is hot, the transmission seems to "pop" from 1st to 2nd and the hotter it is, the worse it becomes, why is this?
2) I want to put my spare up on the roof rack, what should i use for tie-downs?
Old Mar 6, 2011 | 11:20 AM
1998MSO's Avatar
1998MSO is on a distinguished road
Hello and welcome,
In regard to the transmission, I assume you've checked the fluid level? How many miles does your vehicle have? The 'search' feature of this forum is a great resource. I do recall seeing other posts in the past regarding hard 1-2 shifts so you might want to try that.
As for your tire, I don't know but make sure it's tied down really good!
Old Mar 6, 2011 | 08:50 PM
it has 140k on it but the transmission was rebuilt around 125k and had new seals put in around 130k
Old Mar 6, 2011 | 08:56 PM
ncarson1623's Avatar
ncarson1623 is on a distinguished road
Hello,
With regards to the roof rack consider maybe a larger rack then the one the is factory issued because of the weight of the tire. some good kevlar tie downs come in all colors and are cheap they are usually pretty durable
Old Mar 6, 2011 | 10:10 PM
thanks a lot, ill look into it!
Old Mar 8, 2011 | 06:50 AM
old skool luvr's Avatar
Originally Posted by ncarson1623
Hello,
ummm..........is your tire filled with concrete?
seriously, just how much do you think it weighs? (no matter how you read that, it's gonna come across as harsh, but i'm not trying to be) the roof rack is rated for 150 lbs.
as for what tie dows.........any nylon ratcheting straps will work fine, just don't use the ones that you only "pull" to tighten. buy some with an actual ratchet on them.
if the trany was rebuilt 15K ago, why were the seals replaced after only 5K? have you had it back to the trany shop that rebuilt it? i know it's more than likely out of warrenty, but you shouldn't be having issues with it already.
Old Mar 8, 2011 | 08:13 AM
the tranny was rebuilt with the last owner who did it himself. it was less than stellar work because after being on the freeway for about five minutes it started leaking all over so i had to take it to the shop where they replaced the seals and no leaking or anything since
Old Mar 8, 2011 | 08:56 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Corvette servo plus a shift kit can leave 2nd gear pretty stout. Unless some modification was done, it shouldn't be doing that. I think if you elaborate on 'pop'... such as audible, or physical?
Old Mar 9, 2011 | 09:38 PM
physical, it's not so much loud, but i can feel it like a strong pull forward
Old Mar 10, 2011 | 12:25 AM
have you ever driven anything with a **** kit in it? is it somewhat like that 1-2 shift?
could be your trany has some dirt in the valve body somewhere, making a valve stick slightly.
Jakethegreat440
Jun 12, 2012 11:58 AM
ro98blazer
Apr 27, 2012 11:41 AM
crblaz98
Jan 27, 2011 08:46 PM
Kwillia
Nov 20, 2010 07:11 PM
bill737
Aug 26, 2010 07:13 PM
