Courtesy lights fuse blowing, taking out horn, wiper, mirrors...
Old Feb 5, 2006 | 01:25 PM
higgy's Avatar
higgy is an unknown quantity at this point
Default Courtesy lights fuse blowing, taking out horn, wiper, mirrors...
How to find the problem with 97 Chevy Blazer S10 20 amp courtesy-light fuse blowing, which controls horn and rear wiper and interior lights and electric mirrors?
Just wondered if anyone else had had this problem, before I go pulling everything apart.
Old Feb 5, 2006 | 05:27 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
Default RE: Courtesy lights fuse blowing, taking out horn, wiper, mirrors...
Try putting a 25 amp fuse or maybe a 30 it will be risky.
Old Feb 5, 2006 | 06:04 PM
higgy's Avatar
Thanks - Tried that already, and no luck.
Old Feb 5, 2006 | 06:31 PM
I would NEVER recommend putting a higher amperage fuse in place of the stock sized fuse. That could lead to a fire in your vehicle due to allowing more current to flow before the fuse would blow. Most likely, you've got a pinched wire that is grounding out. More amperage = more heat.
When you do dig into this (and you probably will have to), you'll have to inspect ALL of the circuits affected. To rule out some of them, you can for instance disconnect the horn and test the positive terminal on the connector for continuity to ground (with the fuse out). Then move on to other systems on the circuit and repeat until you find the source of the short. It won't be fun, but I do hope that you get it corrected!
Old Nov 29, 2009 | 02:06 PM
Rathbone's Avatar
Rathbone is on a distinguished road
Originally Posted by swartlkk
... To rule out some of them, you can for instance disconnect the horn and test the positive terminal on the connector for continuity to ground (with the fuse out). ...
Can you explain for me how this is done?
Thanks,
Russ
Old Nov 29, 2009 | 03:09 PM
Do you know how to use a multi-meter? Most multimeters have a continuity test mode. Touch the probes together and the MM will give an audible tone.
Dean Davenport
Jul 18, 2019 12:08 PM
dmauriceabcd
Sep 17, 2011 03:21 PM
macdaddy25177
Feb 13, 2011 02:07 PM
JTalley
Dec 18, 2010 06:33 PM
schums
Sep 22, 2007 06:02 PM
