cranks won't run
Old Sep 20, 2012 | 03:00 PM
gbvinla's Avatar
gbvinla is on a distinguished road
Default cranks won't run
Have read severl articles about this problem. Checked fuel pressure at schraider valve with key on, engine not running. 45psi initially and 38psi at 10 minutes..Normal or abnormal? Where do I go from here? Initially (before finding you guys) I changed the ignition switch. Didn't have problem for about 2 wks. Turns over and is about to crank.When release key to "run" cycle, it doesnt run. New batery.
Old Sep 20, 2012 | 03:17 PM
rexmburns's Avatar
Super Moderator
Your pressure is way to low! sounds like a bad fuel pump to me. You should also have this moved to the appropriate section by one of the mods.
Old Sep 20, 2012 | 03:54 PM
gbvinla's Avatar
Thanks Rex. I'm new here. Where should it be and how do I get Moderator to change it? Had a 91 fuel pump go out and had to drop rear end to drop tank. Same on 02???
Old Sep 21, 2012 | 03:20 PM
SpeedAddict81's Avatar
SpeedAddict81 is on a distinguished road
Shouldn't have to drop the rear end, didn't have to on my '01. Do you have MPFI or whatever the throttle-body injection is? (I can't remember if they switched mid-02 or in 03)
Old Sep 22, 2012 | 07:00 PM
gbvinla's Avatar
It's a throtle-body. Finished the R&R of the fuel pump. What's with those clips on the fuel pump connectors?? Figued them out, but geez! Truck runs like a top. Starts like it is supposed to. Thanks to all who replied and those that posted previously about this problem. Will be checking back soon.
kwbond
Mar 18, 2014 12:39 AM
bsbob
Jul 22, 2011 12:48 PM
swartlkk
Dec 10, 2009 01:22 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
