Creaking Noise Under Track At Low Speeds
Old Mar 26, 2005 | 06:43 PM
XtremeYellowChvy's Avatar
XtremeYellowChvy is an unknown quantity at this point
Default Creaking Noise Under Track At Low Speeds
I dont know if anyone can help me out with this, at low speeds with the windows open, a creaking noise coming from either the front or rear tire area, maybe possibly a rear wheel bearing, I know i had multiple problems with them in my 2000 zr2, thanks
Old Apr 8, 2005 | 04:17 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: Creaking Noise Under Track At Low Speeds
I've had the same problem just this morning, but I thought it mighht be because of the moisture from overnight on my brakes...
Have you figured it out yet?
Old Apr 9, 2005 | 09:26 AM
ps2eric2000's Avatar
ps2eric2000 is an unknown quantity at this point
I have that happening in my 02 Xtreme also, I am leaning toward the struts on the back hatch window.
Old Apr 11, 2005 | 09:15 AM
m00nwater's Avatar
Mine's actually from the front driver's side. I am thinking it might be something as simple as the brake pad. It stops when I speed up past 60 K (I don't know the equivalent in miles, I'm Canadian ). It also stops when I brake, so I think that's all it is.
Old Nov 14, 2005 | 12:49 PM
apollo's Avatar
apollo is an unknown quantity at this point
I have the same problem has anyone figured it out yet????
Old Nov 14, 2005 | 01:49 PM
Talusgirl's Avatar
Talusgirl is an unknown quantity at this point
Same here, really irritating. Nice thing about cold weather is that the windows are up-so I don't have to listen to it.
Old Nov 14, 2005 | 02:17 PM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
mine does the same thing when i got under the rear and started tryin to find it i moved the rear sway bar and it was coming from the bushings i dunno if it the same spot on yours but check it out
Old Nov 15, 2005 | 03:01 AM
Annekat91's Avatar
Annekat91 is an unknown quantity at this point
I noticed a creaking noise all summer when going slow with the window open, but especially over bumps. So I thought it was the leaf spring bushings, and lots of silicone spray later, it was still doing it. While in the shop for a tune-up, a mechanic thought it was the left rear shock, which I didn't believe. The shocks were new, and when I told the friend who installed them that, he laughed and said shocks don't make that noise. Then I took it into a different shop for an oil change and lube, a place that installs lots of shocks, and they also said it was the left rear shock. They said you generally aren't supposed to put lubricant on shocks when installing them, but they put a little chassis grease on that one, I guess on the rubber bushings, to see if that would help. It didn't at first, but then it seemed I was hearing the noise less and less. Of course, now the window is up, so I don't know whether it still does it. In any case, both mechanics said it wouldn't hurt anything to drive it that way, but that I could probably get the shock replaced under warranty. (It's been 2000 miles since the shocks, so I guess I'd have to replace them as a pair? Probably won't bother at this point.)
Well, since Blazers seem to have so many variations on weird noises, it's probably not the same creak as the rest of you are experiencing! But I thought I'd relate my story anyway.
rickyp3278
Sep 17, 2010 12:14 AM
LunchBox
Mar 21, 2010 09:15 AM
kaejr
Jan 16, 2008 08:32 AM
JustinF01
Oct 24, 2007 12:50 PM
Lockback
Aug 22, 2007 12:24 PM
