Cruise Control not working...
Old Dec 31, 2008 | 07:22 AM
bobbye's Avatar
bobbye is an unknown quantity at this point
Default Cruise Control not working...
I've got a 96 4 door 4X4 Blazer and my cruise Control doesn't work. The fuses are all ok. I know it works in conjunction with the brake switch.
My question is: Would the high mount brake(3rd brake) light cause it to not work if it is out?
Thanks, Bob
Old Jan 1, 2009 | 01:07 AM
AJBert's Avatar
Default RE: Cruise Control not working...
Nope, the third brake light has no effect on the cruise control. If none of your brake lights are working, then the switch is your culprit.
Old Jan 1, 2009 | 08:26 AM
bobbye's Avatar
Okay, thanks. That's what I thought.Lights work except the 3rd.When it warms up, I'll dig a little deeper into it.
Old Jan 1, 2009 | 10:13 AM
Mammys Car's Avatar
Mammys Car is an unknown quantity at this point
My '96 had a cracked hose at the vacuum reservoir (the spherical ball about 4" in diameter located on the driver's side near the firewall). Easy fix and the cruise works well now.
That entire vacuum hose system is suspect to cause the cruise to fail, trace the hose looking for cracks. A bad leak also will cause the ventilation air to come out the wrong vents under hard acceleration in a high gear.
Of course, the switch on the brake pedal can also kill the cruise if it's misadjusted or kaput.
Good luck.
Old Jan 2, 2009 | 07:54 PM
icculusjr's Avatar
icculusjr is an unknown quantity at this point
I agree with Mammy. I used to have a Chevy Corsica a while back and the cruise control went out on it twice. Both times it was a leak in a vacumn hose.
RobR
Sep 28, 2014 03:16 PM
gatorboy44
Nov 4, 2011 10:35 AM
S10Frank
Jun 7, 2011 06:12 AM
Steinbruchsoldat
Dec 18, 2010 08:32 AM
6wraith
Jun 27, 2007 12:44 PM
