CTSY LP Fuse Keeps Blowing Out. Please Help!!!
Old Apr 23, 2007 | 12:02 AM
xAnarChisTx's Avatar
xAnarChisTx is on a distinguished road
Default CTSY LP Fuse Keeps Blowing Out. Please Help!!!
Hey everyone. I am having problems with my CTSY LP fuse (10A) blowing out. When this happens, my reading lights, dome lights, 4x4 buttons, and keyless entry goes out. Now, I have tried to figure out what exactly the problem is, and so far this is what I have found:
At times, my keyless entry stops responding when I try to remotely unlock my doors, and the only way to get it to work again is to take out the fuse and pop it back in again. I check the fuse, but it is not blown. If I let the fuse sit in there, and NOT use my keyless entry, it blows out, and it leaves me clueless as to why it does this.
Now, do you think that because the keyless entry stops responding, it could blow the fuse out if I use the power locks to lock and unlock my car doors?
Oh, and I have a 2001 GMC Jimmy, 4.3L.
Old Apr 23, 2007 | 12:46 PM
Default RE: CTSY LP Fuse Keeps Blowing Out. Please Help!!!
I would start by disconnecting your RKE module (above the driver's side hush panel directly behind the DLC - data link connector). Drive around with it like that for awhile. If the fuse still blows, then you're probably going to have to dig into the wiring and make sure that there isn't a wire grounding out, causing the fuse to blow.
Let us know how it goes with it disconnected.
AustinBlazer
Jun 4, 2013 10:35 AM
Derick
Sep 11, 2012 11:57 AM
X Gixxer 1000 X
17
Aug 30, 2011 02:11 PM
Janis
Aug 5, 2011 08:05 PM
live4camaros
Jul 12, 2006 01:24 PM
