CV Axle Assembly Replacement
Old Oct 8, 2011 | 08:07 AM
LannyL81's Avatar
Default CV Axle Assembly Replacement
If anyone has read a posting about being able to pull the CV Axle Assembly throught the spindle by removing the wheel bearing....IT DOES NOT FIT.
I replaced the driver's side CV Axle Assembly and also found the lower ball joint pretty shot. I could not get the lower ball joint to separate, so I removed the ball joint bolts and took the spindle off and then I was able to get the ball joint out.
When I had everything apart I thought I would try the CV Axle Assembly through the spindle...with bearing removed...NOPE....IT DOES NOT FIT.
Just passing along information.
Oh and getting the CV Axle Assembly out and back in.....is a chore!!!
Old Oct 8, 2011 | 08:12 AM
chris015's Avatar
Yep. I learned the hard way too.
Old Oct 8, 2011 | 04:12 PM
98blazin's Avatar
98blazin is on a distinguished road
+1 , does not fit through the spindle... but mine was a peice of cake to remove and re-install in the diff.
thrandall
May 3, 2013 04:54 PM
venom4me
Jul 2, 2011 02:39 PM
cbur307736
May 5, 2011 07:27 AM
Tony H
Jul 29, 2009 11:38 PM
KLBlazer07
13
Jan 14, 2007 04:16 PM
