4WD Hub Assembly replacement
Old Jul 29, 2009 | 07:47 AM
Tony H's Avatar
Tony H is an unknown quantity at this point
Default 4WD Hub Assembly replacement
I've done these 1 piece units before on other cars so I have a handle on it..
Can you tell me the Torque of the Axle Nut and te back three Bolts that attach the Assembly, What size Bolt Head and can I get to all three with and impact gun or Rachet or do I need a wrench for at least one of them?
Symptoms. With Tire off the ground, All feels tight when pushing and pulling on the tires. BUT on turns, I feel a metallic growl. My guess is the Bearing is starting to go.
Your Thoughts
Old Jul 29, 2009 | 03:33 PM
Torque values are posted in several other threads along with the bolt sizes. There is a pretty good how-to in the Tech Article (DIY) section if I remember correctly.
I doubt you will be able to get an impact on the 3 attaching bolts. The one up top is a tight fit. I just use a 1/2" ratchet on them and they have always come out just fine.
Old Jul 29, 2009 | 06:32 PM
Tony H's Avatar
I keep forgetting about the Tech section I have a shortcut that brings me to 2nd Gen area and sometimes, like now I move to the Drivetrain section.
There's enough room for a 1/2" dive ratchet, that's a Plus.
Thanks
Old Jul 29, 2009 | 07:14 PM
NVANZEE's Avatar
you can use a impact on the 3 bolts but its tricky. I think i used a 3/8 impact with an extension and a swivel impact socket. I can be done but not usually with your normal socket set
Old Jul 29, 2009 | 07:51 PM
A 3/8" impact would definitely make it easier to fit in. I need to get me one of those.
Old Jul 29, 2009 | 11:38 PM
NVANZEE's Avatar
yeah a lot of the guys at work have them. They are nice
strad
Dec 11, 2010 08:04 PM
Marcin
Apr 13, 2007 01:09 AM
Booztd
Feb 22, 2007 11:08 AM
KLBlazer07
13
Jan 14, 2007 04:16 PM
greengoose89
Aug 3, 2006 07:32 AM
