Daytime Running Light Help
Old Jan 24, 2010 | 02:26 PM
sjas00jimmy's Avatar
sjas00jimmy is an unknown quantity at this point
Default Daytime Running Light Help
Okay so dtoday i installed the resistor for the auto lamps and took the tap off the relay. Now when i take my parking brake off the lo beams automatically turn on what can this be.Could i have installed the relay wrong. Any help would be great thanks.
Old Jan 28, 2010 | 04:59 AM
awe341's Avatar
awe341 is on a distinguished road
Perhaps you could clarify a bit for us what you are trying to accomplish exactly.
Normally on these trucks with properly working daytime running lights, the headlights will come on any time the ignition switch is turned on and the parking brake is off. Though on some models/years they will only come on once the engine is running and you put the truck in gear. (also with the parking brake off)
From how you described it sounds as though your DRL's are working as they are supposed to.
Old Jan 28, 2010 | 12:49 PM
lombard's Avatar
lombard is an unknown quantity at this point
Sounds like he's trying to disable the DRL so he can control the headlights from the switch on the dash.
I can't help with the problem unfortunately.
Old Jan 28, 2010 | 01:58 PM
nj4x4blaze's Avatar
Btw where did you install the resistor? You should have removed your passenger side dash speaker grille and unpluged the automatic headlight sensor and installed the resister there. That will disable your automatic headlights.
Old Feb 7, 2010 | 11:52 AM
blackjimmy's Avatar
blackjimmy is on a distinguished road
Not sure what you are doing ,but if you push your dome over ride button 5 times it kills the drl untill you shut the truck off.
Old Feb 7, 2010 | 12:03 PM
zedartwo's Avatar
Doesn't work on all models!
Did you take the tab off? or just bend it?
Which tab number? some models it's 85, some 86. then reinstall it the exact same way it cam out. You may have the DRL relay. In this case just pull it. its the same size as the fuses, Its just black with some sort of arrow on it.
dratner
Aug 2, 2011 03:21 PM
magtec
Dec 2, 2006 01:37 AM
drefda
Oct 5, 2006 01:32 PM
greengoose89
Jun 2, 2006 03:09 PM
RedBlaze
Sep 14, 2005 01:28 PM
