Daytime running lights
I am having a issue with my daytime running lights that started a week ago. if it is bright outside like normal daylight driving both high and low beam lights come on. if and when it gets dark then the automatic lights kick in and high/low beam work normally. I'm just not sure why or what would cause the daytime lights to activate both high and low beams. I was actually pulled over for it so now i'm turning on the headlights everytime i go someplace. any ideas? relays? Hand grenade?
1998 S10 Blazer 4x4 4.3L auto.
it sounds like your ride did the "quad mod" to itself.
its just a guess but there is a relay in the fuse box under the hood that has to do with the drl system.
it sounds like your ahl works...and your bright switch on the column is working...so that would be my guess....just a guess though.
Depending on what year your blazer is you can turn off the daytime running lights by pressing the dome override button 4 times within 6 seconds.
What years does that work in? I have a 97 and Im not crazy about the daytime runners so if theres an easy way to get them off Id like to know. Thanks..
just do a search on disabling DRL.
you simply have to bend one of the tabs on the DRL relay. search to find wich one, i cant remember i did it a long time ago.
Benedict1337
12-10-2010 08:30 AM
