Defrost Vent
Old Aug 29, 2015 | 05:42 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default Defrost Vent
Alright so I know the defrost vent has been a problem many a times, but this one is a bit different that I can't find an answer to. So I had the defrost stuck on problem and I (think) I fixed it. It works fine and changes fine on the dash and all settings work EXCEPT on the highway... Whenever I'm accelerating or randomly around 70mph the dash vents change to the defrost by themselves and will change back when I let off the gas. All the vacuum lines are connected right and are tight and this still happens, and only on the highway at 65+ mph. Ideas?
Old Aug 29, 2015 | 07:16 PM
LannyL81's Avatar
Did you replace all the vacuum lines under the hood? Sounds like the line to the vacuum reservoir is leaking...but all lines under the hood should just be replaced as they rot-out in 3 to 4 years.
Old Sep 2, 2015 | 05:09 PM
Jamodi's Avatar
Jamodi is on a distinguished road
I've got the same issue but it's all the time. Also when blower is on low I can hear a hissing sound under the dash. I've replaced the upper mode door actuator, but I think the lower mode door actuator is the one out now. I cAnt find the part any where though. Any ideas?
stevo
May 19, 2010 04:02 PM
starcruiser
Oct 17, 2009 10:52 AM
BrooklynBlazer
Apr 25, 2007 06:25 PM
kammino
Nov 27, 2006 11:35 PM
moggy59
Jul 26, 2006 08:50 PM
