did tune-up today
Old Oct 10, 2008 | 07:02 PM
blueblAZer99's Avatar
blueblAZer99 is an unknown quantity at this point
Default did tune-up today
First off thank you everybody for all suggestions on how to go about changing the spark plugs! The #3 plug wasnt that bad to change. Jacked up the truck. Removed the tires and went about it that way. I pulled the sleeve down on the steering shaft and turned the wheel 45* to get the flat spot on the shaft nearest the plug. Then used a swivel spark plug socket to remove it. I broke the spark plug upon removal so was extra careful when installing the new one. Other than that the major PIMA was the stupid@55 wire holder thingamabobs! I spent more time trying to get those stupid@55 things open than I did on the rest of the project. SO the project consisted of AC Delco platinum plugs. Which I pulled Bosch out. Wires, rotor and cap. I am whooped now though!
Old Nov 9, 2008 | 09:49 AM
rlarge2000's Avatar
rlarge2000 is an unknown quantity at this point
Default RE: did tune-up today
Hi, I'm about to do my wife's 2000 blazer 4 dr. not sure if they are the same, but how hard was the rotor and cap to replace yours is the first thread i've seen talking about changing the 2
Old Nov 9, 2008 | 09:32 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
It would be the same its just two torx screws in the cap and the same for the rotor. It only takes a few minutes. I hated those wire holders too they made changing the wires like an hour longer than it needed to be.
Old Nov 10, 2008 | 10:24 AM
rlarge2000's Avatar
thanks, i'll post my experince when i'm done
AreaCode215
Nov 7, 2011 03:07 PM
ExplicitYourSelf
14
Jun 7, 2010 06:25 PM
jdbell2004
Oct 3, 2007 06:46 AM
black19
Aug 20, 2006 10:40 PM
jdpilot
Mar 28, 2006 10:52 PM
