diff oil change?
Old May 1, 2012 | 06:28 PM
dano440's Avatar
dano440 is on a distinguished road
Default diff oil change?
133,000 miles should I change the oil in the front and rear diffs? as far as I know it's never been done since it was new.
Old May 1, 2012 | 06:53 PM
pettyfog's Avatar
I looked in my owner manual pdf and kept seeing reference to footnote but never found it.
Look in yours.
I think it's a good idea. Had mine done when I bought it.
Old May 1, 2012 | 07:24 PM
dano440's Avatar
what would you put back in, just standard gear lube or ???
Old May 1, 2012 | 07:30 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
Mine has a G80 rear which calls for AC Delco 75w90 synthetic, so I just use it in the front as well. Pretty sure the front only calls for regular 80w90 though
Old May 1, 2012 | 08:04 PM
rriddle3's Avatar
I say change out both.
Old May 1, 2012 | 08:37 PM
pettyfog's Avatar
dano.. just use what the owner manual says to. You CAN go synthetic if you want but it's a slightly different paradigm from engine and trans. Esp a road truck.
And here's the thing. sooner or later gonna have to do bearings. Dont reuse fluid, so why go the expensive route.
Old May 1, 2012 | 11:17 PM
dano440's Avatar
I was wondering about synthetic, if it would be a good idea or not. but I see what you mean that sooner or later I will have to tear in to and be throwing it away. I did about 14 months ago had to have a seal replaced on the front diff drivers side. I don't thing it ever run dry, but I bet it didn't do it any good. I am going to look in to changing the oil in them possibly in June I don't have any problems or noises at the moment and getting ready to leave on a trip I don't want to tamper with things to much and create any problems.
I just trying to think of all the things I need to look in to soon since I am trying to get caught up on my maintenance schedule. a lot of things got skipped at the 100,000 mile mark. I changed out the fluid on the transfer case about 12 months ago when we did the transmission, so those are both done. front drive shaft was replace just over a year ago. but the rear shaft and the diff's have had nothing done to them since they were new or prior to (8 years ago) 73,000 mile when we got it.
Old May 2, 2012 | 06:04 AM
pettyfog's Avatar
Well, sounds like you're on top of it. What you can do is pull the rear driveshaft and check the universals for smooth movement.
Old May 10, 2012 | 10:10 PM
dano440's Avatar
pull the drive shaft (rear) and replace transfer case rear seal and checked u-joint last Saturday while I had it on the lift they felt smooth added a little grease to the rear u-joint it was not dry but was not full either. tonight while I was replacing the last upper ball joint and had it on the lift I checked both diffs rear one was full and some what clean oil in it. transfer case was full but... the front was a different story, it was not dry but I couldn't touch the oil with my little finger.
I added 4 oz. of Lucas oil treatment and 8 or 9 oz. of 80 W90 oil to it to fill it up. Any idea how much the front should hold?
chris015
Jun 8, 2012 12:37 PM
blazer blaze13
Sep 27, 2010 12:12 PM
dagda
Jan 12, 2010 06:37 PM
zippy199
Oct 22, 2009 06:36 PM
republic
Sep 8, 2009 08:50 PM
