Distributor problem
Old Jul 28, 2015 | 03:45 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question Distributor problem
Hi gang I recently just got my 96 blazer running with a rebuilt engine.Im having problems with the distributor coming loose,also would this cause the timing to be off if it moved?
Also for some reason its running very warm close to 195* along with poor idling condition.
Also is an attachment of a vacuum line coming off a sensor on the passenger side of the engine,where does it go?
helpful input required thanks.
Old Jul 29, 2015 | 07:15 AM
Thumbs down
Realy I posted this yesterday and after 84 views not one person can post anything to help?What has this forum turned into?
Old Jul 29, 2015 | 07:32 AM
Tajohns34's Avatar
It comes loose after you tighten the hold down? Also 195 degrees sounds fine.
Old Jul 29, 2015 | 12:42 PM
Yes it has came loose a couple of times,it runs like crap and has no power.It also idles realy low after being warmed up.
Old Jul 30, 2015 | 11:06 AM
LesMyer's Avatar
I believe what you are calling a sensor, is the Evap Canister Purge Solenoid. It has a short piece of plastic tubing that leads to a metal line going to the evap system.
Old Jul 30, 2015 | 11:10 AM
LesMyer's Avatar
It's just pretty tough to try to help when you post multiple threads about the same problem. Please decide on one thread for your problem and stick to it. Then we can see not only the history of what you have said - we can also see what you have been advised, all in one spot. It just gets to be too much work, otherwise. I would have answered completely differently in the other thread if I had known you have a possible disconnected vacuum line. Now I feel like I wasted a lot of my time.
Krafty10
Apr 11, 2015 08:03 PM
Cerpindicular
Jul 20, 2011 11:50 PM
dve330
Apr 10, 2011 07:17 PM
dman001948
Nov 10, 2008 12:37 PM
rnjohnson
Jan 28, 2006 09:57 PM
