Do I or do I not have the wiring for RKE?
I have checked my wiring harness behind the dash, and I can't find the wiring that are mentioned in many threads on this forum.
OK, then I don't have the RKE wiring I say to myself.
But when I google this I find this:
"also found out that the wiring is already there because it replaces another module called the dimmer module. The module it replaces is Part #15150325."
Where the RKE should be I got the dimmer module, but this modul has only 5 wires going to it. Could there yet again be a system on the 1995 blazer that are different from ALL other year? I can't find the red progam connector either.
If this means that I don't have the wiring for RKE, are there any other aftermarket ones that don't involve pulling wires all over the blazer?
I know there are a keyless entry system called SPEEDY where you only need to replace the Power door lock realy with a radio controlled one, but I can't find any information to confirm that this will work on my blazer 1995.
Any information more than I have will help
![Smile](https://blazerforum.com/forum/images/smilies/smile.gif)
