Don't care how.. Just get it done!!
Old Dec 22, 2023 | 10:22 PM
Daddy13Carlos's Avatar
Daddy13Carlos is on a distinguished road
Default Don't care how.. Just get it done!!
So i've done the 10 & 30 minute bypass. Did the resister bypass.. tryed adjusting the nss. changed relays and fuses .new battery&connectors,
​​​​​​alternator,starter,ecm,crack&camshaft sencors. New distributor and wires,plugs and new bulbs for any burnt out lights.. And nothing..fml... Now I'm going to attempt to do this solenoid bypass.can some one send a diagram for wiring processes plz and thank you..
Old Dec 23, 2023 | 10:25 AM
GeorgeLG's Avatar
I can help you but I need a description of the actual problem. Impressive parts cannon though.
George
Old Dec 26, 2023 | 06:30 PM
George
sup george..
I'm having trouble with a no. Crank no start 00 blazer 4.3l. overhead,cluster,head hi/low rear,brake,rev,dome dimmer lights work. Grounds are good .I'm thinking nss ..did the new ignition switch and relearn no security light all I get is a "tac tac" sound..
Old Dec 26, 2023 | 06:35 PM
George
sup george..
Old Dec 27, 2023 | 11:13 AM
GeorgeLG's Avatar
What is the battery voltage at the battery terminals at rest and what is the reading when you try to start the truck and get solenoid clicking sound?
sup back.
George
Old Dec 29, 2023 | 05:15 PM
puttster's Avatar
Yo didn't say what year. If it's an 02 like mine the + side terminal can get corroded where you can't see. To get the amps, you have to pull them off and clean them out.
guitarranger11
Oct 3, 2012 09:33 PM
jameseaken
Dec 13, 2010 04:18 PM
patton78
Aug 19, 2008 08:21 AM
wilb86
Nov 19, 2007 09:56 PM
phillfam99
May 1, 2007 09:48 PM
