door problem
Old Sep 12, 2009 | 02:14 PM
Dennis Bradley's Avatar
Dennis Bradley is on a distinguished road
Unhappy door problem
I am unable to close my 2 front doors on my 04 blazer the latch on the door seems to be closed and is not able to engage the pin on the door frame
Old Sep 12, 2009 | 02:22 PM
rriddle3's Avatar
Have you tried using a stout screwdriver to manually rotate the latch on the door?
Old Sep 12, 2009 | 02:32 PM
yes I tried a screwdriver an it did not move. I am not sure if it should be pushed up or down. neither has worked
Old Sep 12, 2009 | 04:31 PM
rriddle3's Avatar
You may need something larger than your screwdriver (like a pry bar) that will fit into the latch opening, and a buddy. Hold the door open and, with the bar, push toward the interior side of the door while you lift either the inside or outside door handle. This should force the latch to pop open.
Old Sep 12, 2009 | 05:10 PM
no luck with the prybar, i guess that thing is made not to give under pressure
Old Sep 12, 2009 | 05:49 PM
rriddle3's Avatar
Hhmm, the prybar + door handle lift should have popped the latch open. How about some info on when and how the trouble started? I doubt that it just happened while both doors were standing open.
teamrojas
Jan 21, 2013 12:30 PM
speedfiend
Jan 31, 2009 01:52 AM
MowJo
Aug 13, 2008 08:52 AM
GMdesigner
Oct 4, 2007 01:55 PM
dropd4door
Feb 10, 2006 02:34 PM
