Dorman Oil Cooler Lines
I replaced the lines on my old 2000 Bravada and had a very similar issue. Mine was just slightly resting on the line. I ended up repositioning the air box and then put a piece of 1/2" hose over the line to further cushion it. I did not get any pictures of it though... I wanted to keep vibration down. Even plastic can rub a hole in a steel line!
Sorry for another off topic question, but would a CAI (like a Spectre 9901 i was looking at) fit if I have a throttle body spacer installed (It's a Helix Power Tower. I didn't install it. I can't remove it because I don't have the original hardware.)? Thanks to all of you for all the advice so far. I totally appreciate it.
1. No tools except basic, basic stuff in my emergency kit (Emergency kit has basic stuff to deal with most roadside emergencies. Large plastic case. )
2. The university cops would approach me if they saw me working on my truck in a parking lot (These are state troopers, by the way, not security guards). There are several cameras covering the parking lots alone. The cops have nearly 100% coverage of the entire grounds except the insides of the individual dorms. They see everything!
3. Don't know how exactly to disassemble the airbox or where to put it in a cramped engine compartment (couldnt even mount the compressor for the star trek horn (size of soda can) with the hoses and power).
4. Don't want to blow the money on a CAI. Need it for more important stuff right now. Don't need the extra 8hp right now.
I mean that should do it then. It doesn't seem "forced" by the airbox. Just no clearance between the two. The plastic clip is flush with the radiator fitting, so I guess it isn't being forced by the airbox. If i can take the air filter access off, maybe I can do that. I'll go to Pep Boys tomorrow and ask. Thanks!
Edit: The corner of the line and the lip of the airbox (See photo) is where they meet.
UPDATE: Well it appears the lines are all okay. They survived the last 600+ miles of driving (plus a very long weekend of high-speed driving, including a roundtrip to home and back this past weekend, which is 360+ miles roundtrip (see signature)) without any leakage or fractures. It hasn't lost any oil since I had it changed about a 1000 miles ago (overfilled actually) Also I forgot to post the photo of how I solved the problem. Here it is.
int3414
Oct 12, 2014 11:30 PM
subarugt06
Mar 6, 2011 11:21 AM
88blackzcand95blazer
18
Feb 7, 2009 09:49 AM
