Driver-side mirror and dash gauge lights
Old Dec 3, 2008 | 01:03 PM
trouty31's Avatar
trouty31 is an unknown quantity at this point
Default Driver-side mirror and dash gauge lights
Trying to squeeze between some junk in the garage (I need to clean that up)and my '95 Blazer earlier in the week, I bumped into the driver-side mirror pretty hard and heard a crack. I went to adjust it, and the whole thing came off in my hands. It's a power mirror, so it is still connected, but I can see thatthe plastichousings that hold the screws have broken off.
Is this an easy fix that I should be able to do myself (I don't have a lot of experience working on autos in general)? Where should I look for a replacement part? Any tips on replacing this would be greatly appreciated.
Also,not sure if it is related, but sincemy "mirror accident"my dash gauge lights do not come on (brake, checkengine, etc. do come on)when I turn on the head lights, andthe head light reminder sound (annoying beep)does not function.
Old Dec 3, 2008 | 04:58 PM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
Default RE: Driver-side mirror and dash gauge lights
a non powered version of the mirror is available at autozone. it is not powered. it is a manual adjust. i am not completely sure if it is the one for your blazer but i know it is the one for my 97. you have to take the door panel off and undo the should be 3 bolts and unhook the wireing harness. you could also look on ebay, and in local junk yards.
Old Dec 3, 2008 | 07:37 PM
Irish10Hockey's Avatar
Irish10Hockey is an unknown quantity at this point
The Driver side power mirror broke off of my blazer as well in a similar fashion as yours with the screw housings breaking. a pretty good solution, although not the prettiest but definitely the cheapest is taking a couple of bolts (3) and bolting it from the inside of the door and placing the nuts on the outside of the vehicle. when the mirror was pulled off it may have disconnected something within the dash panel, possibly an easy fix, i would start by taking the dash apart and checking for anything like that. just a couple of ideas... hope they helped
mamawolf70
Apr 10, 2020 10:44 AM
Wexinlo
Apr 6, 2011 11:35 PM
MintyMadness
Apr 23, 2010 09:43 AM
chevblazer02
Apr 12, 2007 02:23 PM
chevblazer02
Mar 14, 2007 10:09 PM
